Has anyone tried fitting pagid cables to their car and have come across a problem as i have, the neck is to big for the retaining point handbrake lever end. I have opened up the hole and now found the retaining clip won't fit either if anyone has fitted these how did you solve it.
Recent caliper change left me with the impression that the socket in the caliper was just too thick, and tickle with the finger sander for a few minutes, and the floor went right on.
No I have R8 handbrake callipers the problem is with the handbrake lever adjustment end the cable doesn’t fit the retaining bracket. The pagid cables are thicker than the oem ones.
