Pagid handbrake cables
  • bilko0795
    • Feb 2011
    • 1883
    Has anyone tried fitting pagid cables to their car and have come across a problem as i have, the neck is to big for the retaining point handbrake lever end. I have opened up the hole and now found the retaining clip won't fit either if anyone has fitted these how did you solve it.
  • Bowie69
    • Nov 2013
    • 2681
    Recent caliper change left me with the impression that the socket in the caliper was just too thick, and tickle with the finger sander for a few minutes, and the floor went right on.
    Have you changed caliper?
    • bilko0795
      • Feb 2011
      • 1883
      No I have R8 handbrake callipers the problem is with the handbrake lever adjustment end the cable doesn’t fit the retaining bracket. The pagid cables are thicker than the oem ones.
