RS2 Carriers
  • bill
    • Feb 2007
    • 5
    RS2 Carriers
    Hi all,stumbled across this site last night,excellent loads of info.Anyway i have a quick question,Does anyone know if RS2 carriers will fit an Audi S3/tt hub.Cheers Guys
  • panzerwagen
    • 900
    Sorry bud...NO.
    S3 is another type of animal from S2.
    • Corey
      Banned
      • Sep 2003
      • 2793
      Bolt spacing for the struts are the same but as to whether it would match a disc for offset and height ????
      Corey
      01636 822288
      • bill
        • Feb 2007
        • 5
        I have looked at literally hundreds of posts and what i'm thinking is this,if i can get myself floating discs with audi hats,something around 322x30(5x100pcd) attach them to the hub then fit the RS2 carriers to my 996 calliper and all should work well,all i will have to do is grind a little bit on the caliper to allow for the thicker discs,oh and find myself the discs and hats in question
        • Corey
          Banned
          • Sep 2003
          • 2793
          Audi do not do a seperate hat for any disc, it would need to be custom, you can use the 993tt disc (323x32) which we have a hat design for the S3 (image is to show the 996 caliperwith the caliper you have (it does fit.
          But we haven't used the RS2 bracket on the S3 chassis so cannot answer whether this would work.
          Corey
          01636 822288
          • bill
            • Feb 2007
            • 5
            Excellent Corey,looks like a good setup,32mm,4mm extra over standard !!! Thats a little more grinding on the pins then to allow an even thicker disc...Anyhow,what money are you looking at for your custom hats,i've been looking for 993tt discs as i was aware these were 2 piece but they're not so easy to come across...Thanks Bill
            • Corey
              Banned
              • Sep 2003
              • 2793
              Where in the world are you? Very easy to come by, you just have to ask
              Send me a PM and we will sort something out for you
              Corey
              01636 822288
              • bill
                • Feb 2007
                • 5
                Hi Corey,I pm'd you yesterday regarding a few prices for the 322x32 seup,when you get a minute could you forward a few on to me.Thanks for your time bill
