Hi all,stumbled across this site last night,excellent loads of info.Anyway i have a quick question,Does anyone know if RS2 carriers will fit an Audi S3/tt hub.Cheers Guys
RS2 Carriers
I have looked at literally hundreds of posts and what i'm thinking is this,if i can get myself floating discs with audi hats,something around 322x30(5x100pcd) attach them to the hub then fit the RS2 carriers to my 996 calliper and all should work well,all i will have to do is grind a little bit on the caliper to allow for the thicker discs,oh and find myself the discs and hats in question
Audi do not do a seperate hat for any disc, it would need to be custom, you can use the 993tt disc (323x32) which we have a hat design for the S3 (image is to show the 996 caliperwith the caliper you have (it does fit.
But we haven't used the RS2 bracket on the S3 chassis so cannot answer whether this would work.Last edited by Corey; 14 February 2007, 15:48.Corey
01636 822288Comment
Excellent Corey,looks like a good setup,32mm,4mm extra over standard !!! Thats a little more grinding on the pins then to allow an even thicker disc...Anyhow,what money are you looking at for your custom hats,i've been looking for 993tt discs as i was aware these were 2 piece but they're not so easy to come across...Thanks BillComment
Where in the world are you? Very easy to come by, you just have to askExcellent Corey,looks like a good setup,32mm,4mm extra over standard !!! Thats a little more grinding on the pins then to allow an even thicker disc...Anyhow,what money are you looking at for your custom hats,i've been looking for 993tt discs as i was aware these were 2 piece but they're not so easy to come across...Thanks Bill
Send me a PM and we will sort something out for you
Corey
01636 822288Comment
