RS2: Help with ABS warning light and error code
  • npvpositive
    • Apr 2019
    • 57
    • Home: England Current: Australia
    I've been getting an intermittent ABS warning on the RS2. My mechanic found the following fault code logged:
    00649 - ABS Inlet/Outlet Valve; Rear (N160)
    35-10 --- Intermittent
    Can anyone decipher this fault code for me? Thanks!
    Nick
    1995 Audi RS2 . . . plus a few other old German cars
  • s0_big
    • Dec 2009
    • 685
    Found this, from S2central.
    00649 Rear I/O Valve (N160)
    - Open circuit in wiring. Short to +ve or ground between electro-hydraulic unit (N55) and ABS controller (J104) - Trace and repair wiring
    - Right front ABS inlet/outlet valve (N160) is faulty. - Check N55 & test with VAG1710
