Braking issue on 2.3 20v CQ
  • Sluttysmurf
    • May 2014
    • 152
    After driving my car for a short while the more I brake the brakes seems to not release fully and over a short time the brakes hold on on all 4 corners.
    so you end up riding the clutch to get the car to move anywhere and when u come off the
    accelerator the car the car comes to a stop.
    so pretty much makes the car un driveable.
    it was fine for ages.
    now my dad and I are scratching our heads on what it could be.
    as it doesn’t have a servo.
    is or the ABS pump?
    is it the brake booster?
    what the hell is it! I just want to get in the car and drive it, but I physically can’t,
    has anyone had a similar thing happen to them? Or know what the problem could be?
    any help would be amazing people.
    as it’s so frustrating.
    This gallery has 2 photos.
  • Bowie69
    • Nov 2013
    • 2675
    Check your rear calipers, the handbrake mechanism seizes up with monotonous regularity.
    Also check cables while there.
    If tweaking the handle brake lever on the caliper fixes it, then you know what to do....
    • Jaswan
      • Apr 2011
      • 757
      Master cylinder?
      Jase.
      • Sluttysmurf
        • May 2014
        • 152
        I had all the handbrake cables checked and changed as I thought that was the problems at first… I was wrong!
        • Sluttysmurf
          • May 2014
          • 152
          Originally posted by Jaswan
          Master cylinder?
          Jase.
          Well I have tried looking for a new one but struggling.
          I don’t want to buy second hand incase that’s no good.
          • John.
            • 2607
            I had similar on my CQ, replaced the MC with a spare(not new) I had. This sorted it.
            • Sluttysmurf
              • May 2014
              • 152
              Well I shall go down this route next I think and hope it works lol
              thank you.
                • 16225
                I does have a brake servo but it’s a hydraulic one. It’s in between the pedal pushrod and the master cylinder. It sounds to me like the servo is applying the brakes all the time without you pressing the pedal. You could try taking the power steering pump belt off and driving it to prove the point but beware.. the steering will be very heavy and the brakes will need a good push to stop the car!
                Also
                Have a look under the dash and make sure the brake lever is returning fully and not riding on the pushrod.
                • Sluttysmurf
                  • May 2014
                  • 152
                  Well let’s try this
                  This gallery has 1 photos.
                  • steve briance
                    • Aug 2014
                    • 1455
                    Lets hope it is that and not the servo itself as newsh suggested.
                    Taking the power steering belt off is a very simple (and free!) check to do and may just save you blindly swapping another component. The master cylinder isnt going to apply pressure without being pressed by something, whether that is your foot or an internally failed servo leaking pressure from the pump to the rod that pushes the m/cyl...
                    • Sluttysmurf
                      • May 2014
                      • 152
                      Does anyone know how to take this bloody thing apart? To change all the seals?
                      m we have taken the C clip off but it won’t come apart
                      • Bowie69
                        • Nov 2013
                        • 2675
                        There's a snap ring, visible in the first pic, two sharp flat screwdrivers should get it apart.
                        Do you have a new circlip/snap ring in the seal kit?
                        • Sluttysmurf
                          • May 2014
                          • 152
                          Where? Or am I being blind?
                          • Bowie69
                            • Nov 2013
                            • 2675
                            • Bowie69
                              • Nov 2013
                              • 2675
                              Left hand outline shows the ring clearly visible just inside the aluminium casting.
                              Right hand circle highlighting the gap in the snap ring where you get your screwdrivers in.
