Mot advisory rusty bomb
  • Mot advisory rusty bomb
    Put the coupe in for MOT .today ,2 issues , brake bomb rusty ,and fuel pipe from tank to filter . How much of a problem to fix theses issues . I assume it’s a new bomb if available ,or can they be refurbished.
    The bomb has extremely thick metal and is very durable. If you haven't got a brake warning, give it a wire brush and treat the rust then re paint.
    The fuel line is a little more difficult as i think they are nla. Can be made up with cunifer pipe. I have seen aftermarket ones on fleabay.
    Silver RS2 Project
      I think that's the fuel pipe that is plastic on the 3B?
      I re-used the original ends and some generic plastic fuel pipe, was quite easy IIRC.
      You warm the pipe in boiling water (or use a paint stripper gun carefully) and push the ends in?
        That’s great thanks . John is it a pig to change , as far as getting covered in petrol ?
          Originally posted by 220bhp View Post
          That's great thanks . John is it a pig to change , as far as getting covered in petrol ?
          I can't remember but I think you'll need to drain the tank..
