A8 discs
  • hybridavant
    • Nov 2006
    • 93
    A8 discs
    Hi can anyone tell me if these are the correct A8 brake discs for big brake conversion?
    Part number 4D0615301J
    Dimensions 323X30 5/112.
    If so what calipers do i need to go with them ?
    That is the correct P/N. Calipers that work with RS2 brackets (at least on an UrS4/S6) are the Porsche Brembo 993tt (big Reds) and 928GTS (big Blacks).
    IIRC
      Do I get a ginger biscuit?
      • hybridavant
        • Nov 2006
        • 93
        Originally posted by newsh
        Cheers mate nice link .
        This link aims to get the brakes behind std avus 16" wheels,wonder if the discs in my first post will go under 17" ?
        And yes i rekon you deserve a ginger biscuit mate
        • BRY
          • 3755
          It will go under, just
          314mm discs will give more clearance behind that wheel, if you alter the bracket to suit.
            Not with RS2 brackets, use Seat machined ones.
            Thats my old S2 and the caliper used to touch the wheell on 16" before Alistair changed them to 304, there was marks on the calipers to prove the that.
