just a quick question what front brakes are you all using
which way to go
porsche 996/boxster 2 monoblock calipers, audi a8 323x30mm discs and Ferodo Ds2500 pads with RS2 hardlines. Well practised mod on here and parts reasonably priced and easy to get hold of. Do a search on here for any of those and you'll stumble over hours of reading
Good luck
Davidsigpic
1992 3b S2 Coupe
Originally posted by s2driveruk View Postporsche 996/boxster 2 monoblock calipers, audi a8 323x30mm discs and Ferodo Ds2500 pads with RS2 hardlines. Well practised mod on here and parts reasonably priced and easy to get hold of. Do a search on here for any of those and you'll stumble over hours of reading
Good luck
DavidRagusa Coupe gone!
BRY sourced kit consisting of 996 monoblocks, Textar pads, grooved 314mm discs, custom brackets, RS2 hard lines and all hardware . Send him a PM for what he's got available.
2nd hand 996s are a very cost effective way to go and will fit under the ABY alloys, not sure about the 3B alloys though. Obviously not a consideration if you're fitting new alloys just looking at your avatar).Cheers'en, AndyC
