Anybody tried the Mov'it/Porsche conversion?
There is a huge experience of brake mods on this forum - do a bit of a search through the brakes section and see what people have done. Porsche mods are very common here, coming in all shapes and sizes, and there is at least one person with an AP mod (Lee I think??).
There's also a company called Hi-Spec who produce 4/6 pot calipers, a couple of people here have had their kit on the S2 also...
Depends on your budget, and whether you fancy getting your fingers dirty doing it yourself, or getting someone like QST, or HiSpec, to fit it all for you.
As well as what capliers to have, there is the question of what discs, then which caliper brackets to get, and then what pads...
A "common" setup here might be something like this:
Porsche 4-pot calipers (993/968 etc)
Audi A8 discs (314mm, or machine them to 304mm)
RS2 brackets
RS2 bolts (plus some spacers if you go for 314mm)
RS2 hoses
Some "fast road" pads, eg EBC Reds, or Ferrodo something...
Last edited by dan_b; 7 February 2004, 11:56.Ex S2 owner, now running around in an A4 Avant quattro...
I have the "off-the-shelf" AP kit on the front - same as QST is selling. They are good but I think you can do better. What size wheels do you have? If you have 18s I would highly recommend speaking to Lee about his 6 pot AP/RS4 discs/custom metalwork - Probably not much more expensive than the AP kit and is a lot better.
I have had brake fade on my setup - might be due to crap fluid though - and it was on a tough track.S2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8
I got it some cool stuff from Switzerland....
and the RS2 conversation beginning...Attached FilesKarel
:deviltail Hungarian Audi Hooligan :deviltail
....Attached FilesKarel
.....Attached FilesKarel
.......Attached FilesKarel
Hi Curlyks2
Shop around before you buy. another lionk on the forum listed a stoptech kit at a good price.
http://www.s2forum.com/forum/showthr...1135#post21135
Hi TunedS2
You seem to have an RS2 kit!!
I hope that you manage to get it working ok.
The disks are coated/plated. I am truying to find out what it is.
It isn't nickel plate electroless or otherwise
not Cadmium plate,
not Zinc passivate. I will try to find out what it is and let you know. aftermarket disks are not plated or protected. and go off quickly.
I will post when I know. Any suggestions anyone.
Sorry for link hijack.
David
