Anybody tried the Mov'it/Porsche conversion?
  • curlyks2
    • 1069
    Does anyone have any experiences of the Mov'it/Porsche or AP Racing (front) brake conversion available from QST?
    (Note the QST linked page shows a Mov'it 322mm disc size - there's also a 342mm which isn't on their site yet.)
    Any alternative suggestions for an S2 coupe?
    Cheers.
    Shocked, exhausted, hosed, bushed, dumped, chipped, mounted, filtered, gauged, packed, intermittantly wiped and braked. I mean broken. Now, about the car...
  • dan_b
    • Sep 2003
    • 3670
    There is a huge experience of brake mods on this forum - do a bit of a search through the brakes section and see what people have done. Porsche mods are very common here, coming in all shapes and sizes, and there is at least one person with an AP mod (Lee I think??).
    There's also a company called Hi-Spec who produce 4/6 pot calipers, a couple of people here have had their kit on the S2 also...
    Depends on your budget, and whether you fancy getting your fingers dirty doing it yourself, or getting someone like QST, or HiSpec, to fit it all for you.
    As well as what capliers to have, there is the question of what discs, then which caliper brackets to get, and then what pads...
    A "common" setup here might be something like this:
    Porsche 4-pot calipers (993/968 etc)
    Audi A8 discs (314mm, or machine them to 304mm)
    RS2 brackets
    RS2 bolts (plus some spacers if you go for 314mm)
    RS2 hoses
    Some "fast road" pads, eg EBC Reds, or Ferrodo something...
    • Doug_RS2
      • 3847
      I have the "off-the-shelf" AP kit on the front - same as QST is selling. They are good but I think you can do better. What size wheels do you have? If you have 18s I would highly recommend speaking to Lee about his 6 pot AP/RS4 discs/custom metalwork - Probably not much more expensive than the AP kit and is a lot better.
      I have had brake fade on my setup - might be due to crap fluid though - and it was on a tough track.
      • TunedS2
        • 130
        I got it some cool stuff from Switzerland....
        and the RS2 conversation beginning...
        Karel
        :deviltail Hungarian Audi Hooligan :deviltail
        • TunedS2
          • 130
          Karel
          • TunedS2
            • 130
            Karel
            • TunedS2
              • 130
              Karel
              • TunedS2
                • 130
                Karel
                • TunedS2
                  • 130
                  Karel
                  • TunedS2
                    • 130
                    Karel
                    • dan_b
                      • Sep 2003
                      • 3670
                      Have those discs had some special surface coating treatment, they look great
                      • TunedS2
                        • 130
                        hell yeeeah
                        many work...but...you know
                        Karel
                        • Stick Insect
                          • Dec 2003
                          • 2338
                          Hi Curlyks2
                          Shop around before you buy. another lionk on the forum listed a stoptech kit at a good price.
                          Hi TunedS2
                          You seem to have an RS2 kit!!
                          I hope that you manage to get it working ok.
                          The disks are coated/plated. I am truying to find out what it is.
                          It isn't nickel plate electroless or otherwise
                          not Cadmium plate,
                          not Zinc passivate. I will try to find out what it is and let you know. aftermarket disks are not plated or protected. and go off quickly.
                          I will post when I know. Any suggestions anyone.
                          Sorry for link hijack.
                          David
                          • dan_b
                            • Sep 2003
                            • 3670
                            Eer, Rust perhaps?
                            • Stick Insect
                              • Dec 2003
                              • 2338
                              Er no Dan, I meant the original coating for the disk....
                              I know what rust is, I have lots of cars with it. Apart from the Audi
                              David.
