A couple of question about bleeding? Need Help
  • Jonas_R
    • 3781
    • Country: Denmark
    Hi,
    Was doing the rear calipers and then went onto bleeding the system, the old way. But sadly I forgot to keep an eye on the brake fluid container and it got way to low, and now I have air in the system.
    My car is a 1992 3B LHD model
    So how should I bleed the car?
    1. Clutch - Master / slave first - where is it located? Perhaps a picture.
    Then bleed 500ml?
    2. Master bleed valve ( if fitted, where is normaly located on the s2?)
    bleed 500 ml
    then bleed 2000ml through the remaining valves.
    3. Rear right
    4. Rear left
    5. Front Right
    6. Front left
    /Jonas R.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    I don't think there is a bleed screw on the master cylinder. Other than that I think you've got it about right.
    The clutch slave cylinder is a PITA to get at, as it is located on top of the gearbox. It's a little hard to get a camera in there.
    SS
    • urquattro-island
      • Mar 2006
      • 1915
      • Home: Norway Current: Iceland
      hei
      always start with the wheel that is located furthest away from the fluid reservoir.
      1 rear right
      2 rear left and so on-.....
      japanischer industriabfall nein danke!!
      www.rackeltrim.se Icelandic Division
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        1 rear right
        Not always. But on the S2 that's right.
        SS
        • johne
          • Apr 2007
          • 1405
          See no need for you to bleed the clutch but the rest is correct. I find the systems that feed brake fluid using pressure from a spare tyre into the master cylinder reservoir the most sucessful way of bleeding cars with ABS - especially if you're on your own.
          • Corey
            Banned
            • Sep 2003
            • 2793
            If you are doing it the old method and have just got air into the system start at the nipple closest to the master cylinder, once you have got most of the air out then go back to bleeding from the furthest nipple working closer.
            Corey
            01636 822288
            • Jonas_R
              • 3781
              • Country: Denmark
              Hi All,
              So what your are saying is that I dont need to bleed the clutch? That would of course be nice, but why is it that I dont need to do that?
              /JOnas R.
              • Corey
                Banned
                • Sep 2003
                • 2793
                Even though the clutch is fed from the same reservoir it is a seperate system from the brakes, you might have drained the reservoir of fluid but there is enough fluid within the pipe down to the clutch.
                If the fluid is old though it is worth bleeding as moisture within the fluid will still degrade the seals within the clutch slave/master cylinder. It will prolong their life.
                Corey
                01636 822288
                • Jonas_R
                  • 3781
                  • Country: Denmark
                  Oki, but the only way I can lift the car up is by using a jack. So I have to lie under the car, so the question is, if it is possible to bleed the clutch lie under the car?
                  Is there only one bleed valve on the clutch?
                  /Jonas R.
