Hi all
I've just come back from Eurofest at Castle Combe, the car was surprisingly good on track it handled well and performed well (vid coming soon
) but i have a slight problem with my brakes.
The brake pedal is now very soft and spongy, the first pump after starting the car is normal then after that its very spongy and on the road brakes are almost non-existant which made the drive home interesting.
I've just tested my Bomb and it had 50 pumps before it went solid so i don't think its that, what i think i have done is boiled my brake fluid.
The brakes whilst on track (15 min session) were ok for the first 3 laps and the last 3 they were getting progressively worse but brake performance was still as normal just the pedal went down a bit further and felt softer.
Do you think a brake fluid change is on the cards or is it something else ?
Any recommendations for brake fluid that won't boil so quick ?
Thanks
Matt
) but i have a slight problem with my brakes.The brake pedal is now very soft and spongy, the first pump after starting the car is normal then after that its very spongy and on the road brakes are almost non-existant which made the drive home interesting.
Thanks
Matt
