Hi all,
need some info urgently.
I have the RS2 brakes mounted, with original Textar pads and "original" anti-squeel pads. The pads is the second set after using Ferodo's for 1000km
However the padchange didn't help, the squeeling came back 600km after mounting.
I meanwhile found the threat in which the Plastilube is mentioned and also an official Audi instruction that recommends using the Plastilube in case of brake squeel.
I am now waiting for the Plastilube to arrive for the next experiment.
Now I was wondering (found mixed info) do the anti squeelpads need to be "glued"to the brakepads or not??.
Now they are not glued (at least no glue residue on the Ferodo's).
Are there differnet types of anti squeel pads available? Any experiences
Carlo
Carlo
All that has to be done is to take away couple of milimeters of all edges of new brake pad. That will put away all the anoying souds.
My pads never made a sound and on coupe and I was using some spanish crap (ICER). That prevents the bad performance and burning pads and overheating discs, when using new pads and old discs.
