996 Brake upgrade problems
  • Al Wyn
    replied
    Cheapest i could get £17.23 inc vat
  • BRY
    replied
    They are SEAT brackets and I did machine them.
    I can't get them for £12.74 each BTW.
  • Al Wyn
    replied
    Theres some very cheeky monkeys out there
  • FRED
    replied
    Is there a big saving with the Seat carrier, when you factor in machining costs ?
    I have the RS2 carriers which I'm reliably informed bolt straight on with 323x30 disc and 996 monos. Hope I'm not being deluded here... That stuff has sat in a dang box for nnnnnnnnhhhhhhhhhhhggggggggggggg three years - OMG that is bad.
    Paul
    Seat carriers cost me £12.74 each 6 months ago.(trade price from a stealer) Machining cost me nothing 'cause I work in an engineering machine shop, but it would be cheeky for anyone to charge much more than an hour or so for labour.
    Grant
  • Smith_S2
    replied
    I dont think they are SEAT carriers i'll try and get a picture of the carriers and see what you guys think. I dont think the guy i bought them from would have made that mistake as he is a well known member of this forum!
    I know that you need a HAT height of 60mm. Now is this height(with the disc lying flat on the ground)of the total disc or is it the height of the face where the pad would rub against to the face where the wheel is bolted onto?(again with the disc flat on the ground). Or is there a possibility that i could have different hubs from the standard one s my S2 is a 1993 L Avant ABY?
    cheers
    Smith9669
    replied
    Paul
  • FRED
    replied
    Originally posted by HPmuirt
    Just what I was thinking. As I understand it, the Seat carriers need to be machined to either suit the 314mm or the 323mm discs, but either way, they certainly need to be machined.
    I am running 314mm A8 discs with Seat carriers which had 2mm and 5mm removed.
    Cheers n
    Si
    Mmm... I'm also running 314 mm A8 discs with Seat carriers but I removed 4mm and 8mm from the mounting faces.
    Grant
  • HPmuirt
    replied
    Originally posted by Corey
    The brackets look like SEAT ones that haven't been machined.
    Cheers n
    Si
  • Corey
    replied
  • Smith_S2
    replied
    other picture
  • Smith_S2
    started a topic 996 Brake upgrade problems
    Gents,
    I'm having some problems putting together my 996 calipers on the S2. I have added some photo's and you can see the caliper bolt will not align up with the hole that the bolt is supposed to go into. I'm using A8 323x30 discs, which are the right ones. Is there anything i could be missing and has anybody see this problem before? It seems that i have the wrong disc.
    cheers
    smith9669
