Front braided lines - CQ20
    I'm refurbing my front brakes on the CQ and after replacing the rear lines with braided items, i wanted to treat the front to the same.... i'm a little confused though... as on my CQ the front solid line comes out into the wheel arch, connects to a flexi line, then to another solid line around the strut, then to another flexi line to the caliper
    will a Vagparts braided kit for the front replace both these flexi lines and the solid pipe, or just the lower flexi line to the caliper? Seems a bit pointless replacing just one part of the old rubber hoses
    can anyone enlighen me?
    cheers
  • s2driveruk
    • 12696
    From memory it replaces it but i cant remember the combination. I think they just have braided pipes to the strut hardline and then to the hardline on the arch.
    1992 3b S2 Coupe
      ah ok, i'll ask them when i order what i get... seems funny they'd charge the same for 2 rear lines as for 4 up front
      • Flat on my back
        • Jan 2007
        • 2449
        Well...
        Yes, two lines per side as on my 90 fwd, got mine made by Merlin Motorsport at CC.
        Ring Vagparts and ask 2 , or 4 lines per kit. You need 4 really.
        Carlos.
          indeed. i'll check
          Thanks Carl
          • shortsport
            • Dec 2006
            • 186
            Try Rally design and make your own works out a dam site cheaper than buying ready made
            http://www.rallydesign.co.uk/catalog...ath=85_248_249
            • Flat on my back
              • Jan 2007
              • 2449
              and...
              cut the lines with the thinnest grinding disc you can find in a dremel tool. SS are nice but v.expensive, plated will rust after a bit and alloy only on race cars or showy ones that dont really get driven anywhere!
              Or Pirtek, they do lots of goodies.
              Carlos.
              • Azman
                • Sep 2005
                • 3205
                I got mine off the tinterweb thingy at the bay of theives... I checked and got the set for the 100 turbo, it has both sections for the front....
                BF goodrich BTW
                Dark Grey Avant
                RS2 FARB
                Alloy Subframe Bushes
