Bought the S2 recently with really bad brakes but havent driven hardly at all as it needs work in other areas too.
Had to drive it today as other car in for MOT, the pedal is REALLY soft and can be pushed right down, did the usual BOMB check by pumping pedal but i only have to pump about 12 times and the ! warning light comes on (and pedal still well soft!)
Fluids etc all seem fine, so does this sound like a "really" knackered BOMB?
Will be running 996's and 323 discs as well later this month
cheers
Will be running 996's and 323 discs as well later this month cheers
i'll get them bled through when i get the new disc's & calipers fitted later this month.
