poss Brake Bomb advise?!
  • DarrenM
    • Aug 2007
    • 1227
    Bought the S2 recently with really bad brakes but havent driven hardly at all as it needs work in other areas too.
    Had to drive it today as other car in for MOT, the pedal is REALLY soft and can be pushed right down, did the usual BOMB check by pumping pedal but i only have to pump about 12 times and the ! warning light comes on (and pedal still well soft!)
    Fluids etc all seem fine, so does this sound like a "really" knackered BOMB? Will be running 996's and 323 discs as well later this month
    cheers
    have you checked the brake pipes for condition and leaks?
    • DarrenM
      • Aug 2007
      • 1227
      Yep, all seems fine tho
      The ! warning light wouldnt normally come on whilst driving or braking, its only when im sat ticking over and pump pedal about 12 times it beeps and displays. (first time i've done it today after reading other brake bomb test threads). Car is a 94 ABY with approx 118,000miles
      • LHD_Kid
        • May 2006
        • 3696
        sounds like they need bleeding.... if the bomb has gone, you actually get a hard pedal, not a soft one...
        run the engine and then pump the brake after you have switched off, see how many pumps it takes to go solid....... should be around 50 or so...
        Chris
        • DarrenM
          • Aug 2007
          • 1227
          Yeah, just tried it....bang on 49 pumps and it suddenly went solid! Is that just a case of bleeding system then??
          • LHD_Kid
            • May 2006
            • 3696
            This is what I would try.... is not an expensive thing to do, and is worthwhile anyway...
            Get some decent fluid, I would do all 4 and the clutch... if possible...!
            There are threads detailing exactly the correct order, and best fuid.....
            order is something like NSR, OSR, NSF, OSF, clutch...
            Anyway, good luck.....!
            Chris
            • DarrenM
              • Aug 2007
              • 1227
              Cheers Chris...thanks for your advise i'll get them bled through when i get the new disc's & calipers fitted later this month.
              Just had a call from MOT place, my other Coupes just failed on...(wait for it).............................................o/side rear caliper!! Bloody brakes!!
                hopefully you're in luck Darren and a simple bleed will sort you out...
                I have a duff servo causing similar symptoms
                • 4WheelDrifter
                  • Oct 2004
                  • 5773
                  • Country: Devon
                  Also check the condition of your brake pipes. especially the flexi ones.
                  SS
                  • Matt_D
                    • Dec 2004
                    • 515
                    Darren mine does this and has done ever since i cooked my brake fluid at Combe
                    I have changed the fluid but i need to re-bleed them again as i think theres still air in the system, might try bleeding them with the car running this time to make sure no airs trapped in the ABS unit
                    If its not that then i have been told my brake master cylinder could be on its way out
                    '95 ABY Avant - Sold
                    '98 B5 S4 -MRC400+ = 464ps 741nm
