Porsche GT3 brakes
  • breitling
    • Dec 2005
    • 491
    • Country: Norway
    Porsche GT3 brakes
    What size are the Porsche GT3 front and rear discs and how many mm are the pots in the calipper?
    Audi RS4+Long sportquattro
    www.hansenmotorsport.no
  • terrybullwon
    • Mar 2006
    • 8782
    IIRC Its a 6Pot with a 350mm disc
    Cheers James
    Chef
    • BRY
      • 3755
      The early ones are four pots.
      • terrybullwon
        • Mar 2006
        • 8782
        And the rears on the newer are 4 pots with a 340mm disc.
        And i bet Brys right
        Chef
        • karlblues2
          • Jul 2004
          • 402
          • Home: England Current: Australia
          I used GT3 Carrera Cup 6 Pot Brembos on my S2 with custom mounting brackets. They have different sized holes for the pistons, small moving to large in three pairs. Don't know the size though sorry. I found 362mm AP Racing discs as the best fit with custom hats. These sat behind 18" Avus style rims. I also used Pagid yellow Porsche pads which were good in all conditions.
          My rears remained stock.
          Used to out-brake the ABS so you may want to consider a brake bias controller set up if you go for this on your S2.
          Hope that helps
          Karl
          Oz
          Oct 93 build MY 94 ABY Kingfisher Blue Audi S2 with MD147 turbo :mischeif:u SOLD
          Audi 90 Quattro 20V 1989 7A
          Audi TTRS 2010 APR stage 2 +
          Triumph 675 Street Triple R
