What size are the Porsche GT3 front and rear discs and how many mm are the pots in the calipper?
Porsche GT3 brakes
Tags: None
I used GT3 Carrera Cup 6 Pot Brembos on my S2 with custom mounting brackets. They have different sized holes for the pistons, small moving to large in three pairs. Don't know the size though sorry. I found 362mm AP Racing discs as the best fit with custom hats. These sat behind 18" Avus style rims. I also used Pagid yellow Porsche pads which were good in all conditions.
My rears remained stock.
Used to out-brake the ABS so you may want to consider a brake bias controller set up if you go for this on your S2.
Hope that helps
Karl
OzOct 93 build MY 94 ABY Kingfisher Blue Audi S2 with MD147 turbo :mischeif:u SOLD
Audi 90 Quattro 20V 1989 7A
Audi TTRS 2010 APR stage 2 +
Triumph 675 Street Triple RComment
