Opinion - Anti seeze in the ABS sensor holes
  • 90quattrocoupe
    • Nov 2003
    • 771
    Need opinions. I use anti seeze on just about everything that could be related to areas of a car subject to rust, dissimilar metals(aluminum to steel) and high heat.
    The abs sensors in the hub carrriers have an aluminum cover, with a brass sleeve, surrounded by steel from the hub carrier.
    I want to use anti seeze in the hole. Would the aluminum, copper and zinc properties in the anti seeze compound cause any sensor or fault problems with the ABS system.
    I am just use to older cars that never had all this fancy stuff.
  • A6 AVANT
    • Nov 2003
    • 321
    Can't think of a prob with using anti-seize, as long as it doesn't get all over the end of the sensor!
    Chris
    A6 Avant Tdi 110 because as the fuel prices keep going up I am so happy to be getting 649.8 miles to a tank of diesel!! (£50)
    • Stick Insect
      • Dec 2003
      • 2338
      Re: Opinion - Anti seeze in the ABS sensor holes
      Likewise Greg, with my Morris MInor you can't get the brakes to lock and so you don't need ABS:eek2:
      I was going to use silicone grease but I will now use Coppaslip if that's what you meant Chris.
      David
      • audiman
        • 4827
        Copper grease will be fine as Chris says. Should make replacing in the future a damn sight easier. Wish they did it at the factory!!
        Tom C - www.rcmr.co.uk
        Audi UR Quattro
        Audi 100 C3 2.0 5 cyl 115ps
        Audi B5 RS4 645ps 911nm
