Need opinions. I use anti seeze on just about everything that could be related to areas of a car subject to rust, dissimilar metals(aluminum to steel) and high heat.
The abs sensors in the hub carrriers have an aluminum cover, with a brass sleeve, surrounded by steel from the hub carrier.
I want to use anti seeze in the hole. Would the aluminum, copper and zinc properties in the anti seeze compound cause any sensor or fault problems with the ABS system.
I am just use to older cars that never had all this fancy stuff.
