Fitted my brake conversion,porker 996s,314 A8 discs and all the other required stuff.
Have bled through at least 3 or 4 times using ATE super blue,but still getting a inconsistent brake pedal feel,and at present,not that impressed with the conversion.
There has to something not quite right because of the
996's usually get.
sometimes the brake can be hard and really pull the car up well,other times(most) the word cr*p springs to mind.softer pedal and a lot less braking force.
Bomb seems to be reasonably healthy.Get the(!) after a few days of non use
With a healthy system the brake pedal should remain constant.
Any help be much appreciated
