What is the difference between the ‘S6 plus’ brake calliper and the normal ‘S6’ calliper apart from the part number suffix? Is it that the calliper is slightly larger to accommodate the 323mm rotors? Basically a straight swap with larger rotors?
I can get hold of a new pair of 'S6 Plus' callipers and some new rotors quite cheap and was thinking about doing the change.
I should have put it is more of a necessity now, as one of my front calliper mountings is cracked and it’s a cheap replacement, rather than a performance up grade.
