Brake warning came up on the way home today, Brake fluid's ok but G00 2000 looks low, trouble is I haven't got any, is there anything else I can use, its says "use only mineral oil" on the reservoir, anything I can buy at Halfrauds? Green ATF? Or do I have to wait till the steeler opens monday morning? I've got some Type G ford ATF in the garage
Maybe you can source one of these alternatives at a local factors?
There is Febi Bilstein 7.1 Mineral Base Audi Power Steering Fluid or Pentosin 11S Synthetic Mineral Base Audi Power Steering Fluid
I'd personally hold out for the real stuff for peace of mind even though the above alternatives are quoted to safe to mix with existing G00 2000 fluid.
Get it from the stealer or german and swedish...but i think you will find the part number has changed. (see attached photo)
Do not put atf in it cos it will knacker all your seals
G 004 ooo m2 is the only one to use. hold out untill you get the right gear
using ATF can and will damage your pas pump i should know i busted two pumps before i wised up and started using G 004 000 m2 ATF will eat the seals in the pas pump. better to be safe then sorry later on.
