Awesome RS2 handbrake
  • EspenW
    • Apr 2007
    • 1534
    • Country: Norway
    The handbrake on the RS2 used to be pretty lousy, to put it mildly. However, after being cleaned, lubed and adjusted, it works like a charm
    Cleaned corrosion off the area of the backplate that the side of the pads slides against,put a thin layer of Plastilube there as well. Got a feeling that many forget to do that. Adjusted so it grabs at the second click and completely locks at the fourth click. Will see how long it stays in adjustment, but works exceedingly properly as of right now
    1994 80E Avant
    1986 2L Golf 2 on Alcohol
  • Lloyd
    • Apr 2006
    • 1559
    My handbrake also works like a treat. Not sure how long it will last though!
    RS2+ (now sold...)
    • A80Avant
      • 10873
      • Country: Greece
      mine too.4th click does the job,but i usually am less harsh and use 3clicks and a gear!
      • EspenW
        • Apr 2007
        • 1534
        • Country: Norway
        I always place it in 1st gear as well.
        So you finally got your handbrake sorted out?
        1994 80E Avant
        • A80Avant
          • 10873
          • Country: Greece
          oh yes,it was the 1st thing i fixed when i bough the car.New cables,new pads on the drumlike surfaces,new mechanicms and it works.Only thing is that every 10000kms it needs tightening.oh well...
          • EspenW
            • Apr 2007
            • 1534
            • Country: Norway
            Aha. Seem to remember that you struggled with it (talked about an aux caliper for handbrake duty)
            1994 80E Avant
            • A80Avant
              • 10873
              • Country: Greece
              yes at first i wanted to do that,but only i the original one failed in nootime.So far so good..drastic measures can wait i guess
              • Audi_CQ
                • 940
                • Country: Norway
                Don't adjust it to tight. Brake shoes are "selfapplying" so if they touch the drum they will start to brake and quickly wear out. BTDT....
                • rs2315
                  • Jun 2006
                  • 867
                  Not long
                  rs2315.
                  • maRS2
                    • Oct 2003
                    • 366
                    • Home: France Current: Thailand
                    Espen: does it work like you can make handbrake turn or just good for car park?
                    RS2 chip by mihnea,PKM short IM, forge dump valve, 3" custom stainless exhaust, 18"X8" Porsche 996 rims, conti contact 245/35 Front 225/40 Rear, QR sport top mount, Powerflex bushes, aloy sub frame bushes, neuspeed 19mm RARB,Hard tranny mount, V8 torsen on RS2
                    • EspenW
                      • Apr 2007
                      • 1534
                      • Country: Norway
                      Able to lock up the rear wheels on dy ground now... (not very healthy for the drivetrain, though..)
                      1994 80E Avant
