I'm going to be changing the pads on my original RS2 brakes soon and wondered if I'll need a piston windback tool to push the piston back in?
If so, can anyone recommend where I can get myself one as all my previous cars have been the push back type where you can just use a clamp.
Also, one of my bleed nipples has corroded and snapped off flush with the caliper face. Where can I get a new set of bleed nipples from? Should I just drill and tap out the old one or is it a new caliper job? The other one doesn't look too great either and I'm pretty sure it's also going to break if I try and undo it.
Thanks in advance
Thanks in advance
