Can't find much information on the hat height of the larger S8 disks or the disk thickness used in the GT2 6 pots.
18s and custom carriers required without a doubt, Has this been done?
lol this is exactly what i was planning to do only with the cayenne caliper lol, think it may JUST fut under some big 17"s also not aware of it being done before tho. i know correy has made some carries compatable with the phaeton discs i think it was.
Ant
91' Coupe quattro 20v - project KW V2s and other goodies
now gone 03' BMW 330CI - Sold 08' A5 Coupe 3.0l tdi quattro - Sold 57' BMW 525d M Sport Touring
dont know about the gt2 but i know the cayenna 6 pots are designed for a 350 disc so wouldn't surprise me if the gt2 calipers are the same layout.
Ant
Ant
Cayenne calipers will fit under most 17s if you use a 330mm disc!
they wll but not with the standard carrier, s2 on the way fitted these to his s2, write up on motorgeek. IIRC he used somespacers on the rs2 carrier.
Ant
from what i can tell, the caliper should match up as the diameter is close enough, the thickness is close enough, i assume the pad contact width (if thats its name) will be ok, so the only problem is the carrier, which isnt that big of a problem really, you would need to do something with the rear brakes though!
brackets would be custom anyway, and if i did go this route the rears would be looked at too.....
i'd need goggles to keep me eye balls in place though
