Hello!
Sorry for starting new thread..maybe there is an answer within forum...
Sorry for my English...just need your urgent help.
Today I started to swap front brakes for my S2.
New setup is following:
RS2 322mm brake calipers
RS2 additional brackets....original ones..
Audi A8/S8 front brake discs 323mm
Audi A8/S8 brake pads - the same dimensions as 993 Turbo.
I had a problem with brake pipes/tubes, so I did not attach them at all......
Then I had to finish my job and move car 20m away....therefore I put everything together and put also R18 wheels....something strange happen....I COULD NOT MOVE CAR FROM IT PLACE AT ALL......only somehow with 3000-4000rpm I could move the car....clutch was smelling bad.....
I checked rear wheels ...just to be sure...they were rotating free...
So I have no any idea were the problem is....the only thing that comes in my mind is that something with my new setup is wrong....but what?
Please help....
Some things:
1. hand brake was released
2. brake pads I put without any pushing...just for left caliper I did not press cylinders back into caliper...but as I told, there were not any problems to put brake pads on...
Please help....
Some things:
(I did not have the torque settings)
