RS2 banjo braided lines with 996 calipers?
  • BRY
    • 3755
    #31
    Clive you are correct when you say that the rs2 hard line replaces the caliper flexi and the short hardline (round the back of the strut). The caliper doesn't move in use, unlike the standard one which slides, and the pads are removed from the back of it. You only have to take them off to do the discs. So uncrack them and re-bleed the system when you change the discs will get round that issue.
    • CliveH
      • Jun 2005
      • 1319
      #32
      @Paul & BRY - many thanks for the clarification (and confirmation that I'm not going mad!)
      So basically, the RS2 hardline is the only thing that's needed if you're not going to also replace the flexi line that goes from the strut to the chassis?
      I know you guys know exactly what you're talking about, but I fail to understand how the caliper doesn't move when the wheel is turned, but then anyone who knows me will know that I fall into the category of 'mechanically challenged'...
      Past: S2 ABY coupe RS2 spec with lots of mods, S4 B5 saloon, RS6 C5 saloon, S8 D2 FL, RS4 B7 saloon, S4 B6 avant
      Present: S4 B8 avant, MRC Stage 2
        The caliper does move when you turn the wheel Clive, but not in relation to the strut / hub that its bolted to
        • CliveH
          • Jun 2005
          • 1319
          #34
          aha!
          • mdm
            • May 2007
            • 65
            #35
            so i could just buy a set of rs2 hard lines and these will conect between the caliper and the first flexi on the car side?
            • BRY
              • 3755
              #36
              Yes
              • CliveH
                • Jun 2005
                • 1319
                #37
                that's what I said...!
                • mdm
                  • May 2007
                  • 65
                  #38
                  must have missed that sorry, i was reading and posting on my phone.
                  • mdm
                    • May 2007
                    • 65
                    #39
                    what about using these instead of the rs2 hard lines,
                    • CliveH
                      • Jun 2005
                      • 1319
                      #40
                      Vagparts tell me that this is to replace the stock flexi which runs from the chassis to the strut (and connects to the stock short hardline). The description on their site seems to be a bit misleading.
                      I have a pair on the way next week (despite being told they were in stock when I ordered them last Wednesday... )
                      • CliveH
                        • Jun 2005
                        • 1319
                        #41
                        no problem! impressive multi-tasking though...
                        • europeanme
                          • Oct 2005
                          • 3817
                          can braided lines not be used from the caliper right through to the hardline....which runs....eeerr under the car?!?!?....
                          • HPmuirt
                            S2Forum April Fool
                            • Apr 2005
                            • 3014
                            #43
                            I am a bit late on this and you seem to have sorted it all out, but I can confirm that the VAGparts supplied RS2 flexi line plus the RS2 hard line fits perfectly on an S2 and works very nicely thank you.
                            Cheers n
                            Si
                            P.S. @Orificer Casey - Grooved discs....you numpty
                            Subtle mods here and there
                            2011 A5 3.0 TDi - Lava Grey
                            • rj scotty
                              • May 2006
                              • 2195
                              #44
                              Cheers n
                              Si
                              Hi Si
                              I agree with you to a point, I have just fitted this set up myself.
                              The RS2 hard line/flexi works and fits very well however, from a maintenance point of view its crap as every time you need to remove the disc/pads the hydraulic system has to be disconnected/reconnected and bled for this reason next time I'm working in that area I will consider flexi lines right to the calliper.
                              Just my 2 pence worth
                              cheers
                              And yes grooved/drilled discs are totally unnecessary
                              rich
                              BUT I DON'T WANT A NEW CAR!
                              1995 S2 Avant, Volcano Black
                              • europeanme
                                • Oct 2005
                                • 3817
                                feeling kind of stupid today.....
                                so can I ask a daft question?......does the braided line need to be 700mm??!?!...or is it the dimensions Jas suggested about right....
                                i am in the process of sorting out a set of hoses for my brake up grade....the dilema of do I use one line or go with chasis to strut braided, hard line around strut and then braided from strut to caliper....it's all getting crazy in the old noggin'......and now I am thinking about braided for my rear upgrade!!....time for the faithful search box!!!!...
                                any advice/opinions etc are truly appreciated.....
                                Mike
