Recomended replacement rear calipers (siezed) for UrS6?
Here is a good example of what to expect:
It doesen't show any sleeve in the exploded diagram.
The Audi rebuild kit doesn't contain the handbrake seal! You can source all manner of seals in the correct size from various places.
Trickiest bit is removing/replacing the circlip. No need to disassemble the brake piston assembly. It depends on the amount of damage to the handbrake lever bore. If its only started to get stiff/sticky it might be worth trying to get some more life out of them.
Thats the badger
Yeah that circlip is a major PITA - i vowed never to do it again.
If you buy a Budweg caliper service kit, ALL the seals are included, including the handbrake lever seal
The nylon sleeve i had in mine was a very tight fit in the lever bore - i couldn't get them out when i rebuilt mine.Panthero Coupé quattro 20vt
Imola B6 S4 AvantComment
I reckon that the grease nipple is the way to go then. I might try and find a 2nd hand set, rebuild them and fit grease nipples.
ANyone got a set to donate of for a couple of
UrS6 - Homefry, Bailey DV, PiperX filter, Samco hoses, H&R springs, 3" D/P back zorst, 270bhp and 260ftlb :rock:
Triumph Daytona 955i - mmmmmm :fire:
80 dag dag :driving:
