MOT fail?
  • 20Vcqdriver
    • 829
    MOT fail?
    Right please correct me if I'm wrong but a broken caliper bleed screw should not be a MOT fail so long as its not leaking. No mention of it in the MOT inspection manual other than ensuring no leaks and as it is seized in, what is the difference if its sheared or still has the other 10mm part attached? Asked 2 other people from garages who say it should not have failed. Some facts appreciated. Thanks
    In fact their suggestion of replacing the caliper is probably more dangerous as it could cause an imbalance between the old and new ones.
    1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
  • sdk778
    • Jul 2008
    • 147
    Afaik it is not an MOT failure, i haven't tested a car for 3 years though but it wasn't a failure point then. Either have a re-test done at another station and then complain to the MOT/DOT group VOSA on 0870 6060440 or email them at Enquiries@vosa.gov.uk.
    I would advise you to keep the original failure sheet and also photograph the failure areas on the car. VOSA does state however that you should NOT have the car repaired prior to contacting them, a new test somewhere else is fine but please DO check with them as to whether this fault does add up to a failure before you complain or you may land the new testing station in the brown stuff for passing your car.
    Hope this helps.
    1999 A3 1.8T Quattro Silver
    2002 A3 1.9 TDi 130 6 speed.
    2002 TT Coupe 225
    1997 A8 2.8 Sport
    www.cotswoldvehicleservices.co.uk
    • Nuvo
      • Nov 2003
      • 3825
      I would be inclined to agree with your judgement. Looking at this reference there is no mention of damaged bleed screws. There are a couple of MOT testers on this forum who will be able to confirm this for sure.
      • Acidburn
        • 13459
        I mot'd my coupe gt5s with a missing bleed nipple from the rear drum and all the car needed to go thru a test was aiming the drivers headlight so its not a fail from my experience.
        • K Simmonds
          • Dec 2007
          • 7627
          I have had cars pass an MOT with snapped off bleed nipples with no mention at all.
          1990 B3 2.0 80 quattro.
          1992 C4 2.8 Avant quattro
          1994 MTM RS2.
          1998 B5 TDI quattro Sport.
          2000 B5 TQS.
          • nikmay
            • Aug 2007
            • 112
            • Home: United Kingdom Current: Germany
            As per the VOSA MOT inspection standards it is not a fail, will only fail if bleed nipple is leaking.
            All Hail the mighty Quattro
            • pixsaudisex2
              • Sep 2004
              • 3110
              im suprised they even seen it.
              • dubmeister
                • 522
                Correct!
                As shown in the test manual previously, it would only fail if leaking- on its own it would just warrant an advisory. what exactly did the tester put down as the failure on the VT30??
