Having stripped a set of old pads out of my "new" boxster S calipers and test fitting the DS2500 pads found there is not much room for these shims, are they that important???.....or can they be fitted without any fuss or any modification to pad or caliper??...
I ran mine without shims for a while, then put them on because the pads were squeellng, which was annoying! They are not important in terms of making the brakes work.
They weren't that difficult to fit, just took the pads out, slotted the shims in, then put the pads in.
IIRC they fit into the holes inside the piston and up against the back of the pads..
am I right???....
Is this because your disk is a couple of mm thicker than the original Porsche ones.
I would tend to agree with Sonic. The shims are there to to stop the pads staying in contact with the disk and squealing. You also need the correct Plastilube to make them work correctly.
I am sure a Porsche brake conversion expert will be along soon to confirm.
Cheers,
Steve.
The Perfectionist
When I converted my S2 to monoblocks I found that with the shims fitted the pads were a vert tight fit - left them off for a few hundred miles- they then fitted no probems.
cool thanks what do they look like are they the metal plates with the round blocks on or are they the round discs have been looking around the net and i am still no wiser to what they should be. have you tryed fitting them yet? i can remember you saying you have 30 mm wide discs is there anought room for them. i have 32mm wide discs and i could only just get the pads in, so i think i would stuggle to get them in .
never set your expectations to high that way you are never disapointed
they are the, what looks like, flat black plastic with the 2 silver bosses you mention...they should sit inside the brake piston's....as for trial fitting they fitted inside the pistons but haven't tried fitting completely as I am going to leave that to an expert!!....as I haven't got any tools to push the pistons all the way back into the caliper block..
one thing you might want to do is shop around....I have used specialist cars of malton a few years ago for these..but as I am a lazy bar-steward, I went local...
