anti squeal shims...
  • europeanme
    • Oct 2005
    • 3817
    it's like a lot of other parts...see SEAT bloody brackets!!!....
    • re2500
      • May 2007
      • 2185
      Just bumping this thread as i found it very useful. It seems i'm not the only one that couldn't persuade the shims+new DS2500 pads+new discs all to fit inside the monoblocks. So ive left out the shims for now.
      OMG the brakes are now fantastic for the first time ever (read as "EBC redstuff are dangerously pants"). But the brakes don't half howl for a few seconds after the brakes have been applied, you can feel the vibration through the floor of the car. So i will wait a few hundred miles and pop the shims back in i think...
      Black B3 1990 CQ 2.3E converted to ABY & 6spd. (301bhp) - Now Sold
      "Difficult is worth doing"
      • Henkjan
        • 1705
        the Boxter I have on my S2 calipers do not have the anti squeel pads
        • re2500
          • May 2007
          • 2185
          Do you get reverberant humming or howling after using the brakes?
          • Henkjan
            • 1705
            sometimes some squeaking after braking hard, usually goes away after a few 100m and some bumps
            • re2500
              • May 2007
              • 2185
              After driving it some more that seems to be similar symptoms to me now, I'm sure I can live with it until the pads wear a little.
              • BorisShakhov
                • Feb 2009
                • 224
                • Country: Russian Federation
                #22
                I have ds2500+shims+30mm brembo and there weren`t any problems with installation.
                But I hear a rattle when going over speed bumps.I suppose it`s from pads and disk.
                Should rattle shims be firmly attached to pistons and move together?
                • re2500
                  • May 2007
                  • 2185
                  It depends what calipers you have. AFAIK the RS2 calipers have one round barbed shim per piston. Liek this:
                  The Boxster s calipers (like mine) have a single rectangular shim per two pistons and have two round bosses that insert into the cylinder itself. Like this:
                  Our problem is because we use boxster S calipers that are designed to work with a 28mm front disc. The discs we use are audi A8 30mm thick discs and i believe this is why it is nigh on impossible to fit the shims with new discs and new pads inside the caliper.
                  • BorisShakhov
                    • Feb 2009
                    • 224
                    #24
                    I have done it like this:
                    Rears without caliper removing
