Have got the coupe back on the road and while off..I had changed over the calipers to Hi Spec 4 pots....the whole brake change over has been a nightmare start to finish ..wrong bolts,carriers needing washers to pop up caliper so on meant to be bolt on ..my ar..se
...anyway have got them on but they are sqeeling like mad (and i mean f**king loud ) and pads seem to be catching slightly ..the way they are designed there is no anti-rattle plate or shims which seem crazy as i think this is the problem ..does any one any were i will be able to get shims or a plate to go over the pads to made help my problem
