There is a lot of assumption made about the master cylinder being too small as the brakes are so much bigger. As I've said several times before the RS4/6/R8 master cylinder is no bigger than the S2 version.
It is true there will be a proportional increase in pedal travel when you have larger and/or more pistons as more fluid movement occurs.
BUT
it needs to be remembered that having a larger diameter brake disc coupled with the larger calipers that there will be a proportional decrease in pedal pressure required to achieve the same braking effect as that of standard brakes.
There will be a slight difference in feel on the pedal but that is no different to driving two different cars with different brakes. Once you get used to the change then you can operate the brakes in exactly the same way as normal. The only difference is that when needed there is a huge amount of stopping power available with the added bonus that they are virtually fade resistant.
*as a side note one of the original design criteria of the VW Phaeton was that it must be able to brake from Vmax an unlimited number of times without brake fade, others included the windscreen wipers must work at Vmax*
Ben
BUT
Ben
