Hi guys a quick quiz for you.
I have a 1991 90 2.3 20v which has just failed its MOT. The problem is the rear brakes. When the pedal was depressed the reading was under the required value but if the pedal was held down the reading went up above the value required. Troble is, it still counts as a failure. Any ideas why and what to do about it?
Thanks for any help you can give, I really appreciate it.
Well spotted that man !
