EBC disk for Porsche brake upgrade
  • EBC disk for Porsche brake upgrade
    Has anyone experience with EBC Ultimax disk? Can I use this Ultimax or Turbo groove disk on urs4 with 996 mono calipers? Normaly I go for 323x30mm
    Or if you have any other sugestions what disk is good for this brake upgrade please tell me.
    Audi URS4 1992. 2.2L 169kw
    www.audiclubserbia.com
    Does anyone have advice about 323x30 disk?
      What struts are you using?
      93 S2 Avant Parting
      91 URQ RR
      02 A4 tdi Avant
        I have HP2 struts
          I would just play it safe and go for A8 discs 323 x 30
          93 S2 Avant Parting
          91 URQ RR
          02 A4 tdi Avant
            Yes, I plan for S8 323x30 disk.
            But I am interesting what type of disk for S8 is better for this upgrade. Ultimax seria, or Turbo groove disk? Or some other disks?
              I use EBC grooved and dotted discs on the back, just fitted my second set, they're a decent upgrade from stock.
                They are pretty expensive but look good
                http://ebcbrakeshop.co.uk/p1202770.htm
                93 S2 Avant Parting
                91 URQ RR
                02 A4 tdi Avant
                  turbo grooves are good discs. maybe a little too costly though.
                  i have run them before. i know of lots of scooby owners who run them in the past too. lots then went to DBA's
                  i thought they were very good. could handle the harshness of ebc pads easily. no issues with greens on these. stopped me as quick as an evo 6 on the motorway.
                    And does anyone have experience with ebc Ultimax Disk?
                      Front Discs
                      I used the 1st generation S8 disc from these guys.
                      http://www.brakeparts.co.uk/
                      Part number BDS5873 retailing at £34.25 plus VAT + delivery
                      The disc is actually made by SBS (Scandinavian Brake Systems) and works well with the 996 calipers and standard Textar pads.
                      Everyone will have their own views....I'm sure!
                      Cheers,
                      John
                      2001 996 C4 - Being renovated
