finally got some anti rattle stims to try and stop the brake noise that i have had. i was expecting them to be sticky one side so they stick to the brake pad. the ones i ordered before but were incorrect were but the ones i now have are not do i need to get some sort of glue or will they work like they are ?
anti rattle shims
Tags: None
With my porsche ones i literally just put them in, and then the pads - no glue or anything.
When i took the brakes off last week they were well and truely stuck to each other so im assuming the pressure sticks them pretty well!S2Forum.com AdministratorComment
Yep, in my case (using the RS2 calipers) all different anti-rattle pads I tested had a kind of double sided tape on it.
Tear off the cover, put them in the caliper, put pads in caliper.
Pump up the brakes and the pads are "glued" to the rattlepads.
Hope this helps, I have tested all sorts of rattle pads and greases but the irritating noise is still there!!
No power, no glory!
S4 Avant, 2003, K&N-filter, 18", RNS-E, enough audio
thanks for the replys, i have indeed the 996 mono blocks and have had them apart too many times for warped discs, noises etc and don't want to have them apart again untill the pads wear out. i just want brakes that don't make a blumming noise when you are just crusing up the road. hmm the ones i got from design911 defanatly don't have a sticky surface to them perhaps that's why they were only £10 each compared to £15 others had them priced at. any sudjestions on a glue to use?never set your expectations to high that way you are never disapointedComment
