Porsche 993 Turbo rear brake disk on rear of a Audi RS2?!
  • Audi-Porsche Avant RS2
    • Sep 2008
    • 1041
    • Country: Italy
    Hello, I have a question, do you know if is possible mount the rear 322x28 mm brake disk original from Porsche 993 Turbo on the rear axle of the Audi RS2? I already know that I must change also the calipers, but my problem is the internal and external measures of Porsche 993 Turbo rear brake disk and Audi RS2 rear brake disk. Thanks a lot! Bye
    Alessio
    My life and my loves
    Audi S6 C4 ABT Avant
    Audi S2 Coupe ABY
    Audi S2 Avant
    Audi Cabriolet 2.0E
    • Sep 2008
    • 1041
    • Country: Italy
    Nobody have try it?
    Alessio
    Audi S2 Coupe ABY
    Audi S2 Avant
    Audi Cabriolet 2.0E
    • Albert
      • 1500
      • Country: Poland
      I my opinion the brake pistons will be to big for the rear and you would have to have gigantic front brakes for this setup. This would kill your brake balance.
      AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
        • Sep 2008
        • 1041
        • Country: Italy
        On front of my RS2 I have the big reds with 322x32 mm brake disk, Porsche 993 Turbo have 322x32 mm brake disk on front and 322x28 mm brake disk on rear, I know that normally front brake disk are bigger that rear.
        Alessio
        Audi S2 Coupe ABY
        Audi S2 Avant
        Audi Cabriolet 2.0E
        • Albert
          • 1500
          • Country: Poland
          Not only disks but also the pistons in the calliper
          Front 322 x 32 disk
          Piston 1: 44 mm
          Piston 2: 44 mm
          Piston 3: 36 mm
          Piston 4: 36 mm
          Rear RS2 disk 299mm
          Piston 1: 24 mm
          Piston 2: 24 mm
          Piston 3: 26.5 mm
          Piston 4: 26.5 mm
          Can you see the difference ?
          • ur-s4315
            • 102
            Do you have the specs for a 993 rear disc? I'm planning to go with the 996 carrera rear calipers sometime in the future and it would look great if the 993 rear disc would fit.
            • Albert
              • 1500
              • Country: Poland
              rs2 has rear disk 299 x 28
              but I'm using 5 x 112 S4 300 x 22 mm rear disk for standard S2 bolt pattern and it also works. I had that for a while.
                Rs2 is 299x24mm AFAIK
