Hi All,
Had the PAS pump changed not so long ago (actually onto my 3rd now - don't buy the cheap ones from GSF) but i'm now getting the hydraulic warning light again and the brake pedal is solid in the morning before i start the car, should it be like this or should i still get brakes after being parked up overnight??? When i do the Bomb test (engine ran then off and pump the pedal) i get over 50 pumps before padal goes hard so not sure if it is the Bomb, hope it isn't the pump again...
Cheers,
Cheers,
