I've been working on the car all day today taking my big brake kit off and putting standard brakes back on. All was going well until it came to bleeding them up.. I just cannot do it, whatever I try.
First of all was a manual bleed, in the correct order (rear left, rear right, front left, front right). This left me with loads of pedal travel. We did it again just to be sure.
After no success, I went to Halfrauds and bought 5L of DOT4 and a Gunson Eazibleed, I'm gonna do this and I'm gonna do it right. I'm gonna run loads of fluid through each caliper and there's gonna be NO air in the system. Oh yes.
Done that. Twice. Used nearly 5 litres of fluid. Bled the clutch too, just to be sure. Done it with the engine running. Done it with the brake pedal down to the floor. Done it holding one hand up in the air while singing "Old Mac Donald". I'm really out of options and patience.
Can someone please tell me what I'm doing wrong? The car is still up on axle stands and I haven't actually tried to drive the car, but the pedal goes (very easily, thanks to the lovely fresh fluid) straight to the floor and if I have the car in gear turning the wheels I don't get a bite until right at the bottom. The odd thing we found is that the rears seem to grab first.
The calipers are from a forum member and I don't know how long they've been off a car, but even if they were seized I should get a firm pedal so I'm not pointing at the calipers.
Last time I tried to bleed the brakes myself I ended up trailering the car to my local garage. The guy there didn't do anything different to what I did from what I could see.
The handbrake is OFF too.
Has anyone got any info that'll help me so I can get this done tomorrow?
Please!
Please!
