What holds the rear callipers on?
  • mikeraz1
    • Jun 2008
    • 342
    • Home: Scotland Current: United Kingdom
    I'm having a bit of a problem removing my rear callipers, they studs holding the callpiers on look like they are allankey but none of them will fit!! Think they are 8mm but it dosen't quite fit. Can some one confirm this before I start hitting it with a hammer
    cheers
    mike
  • Flat on my back
    • Jan 2007
    • 2449
    Thought it was 7mm...the one that's always hard to get.
    Back from garage in a mo...off to check...8MM from my check.
    Pick out as much of the rust as you can, WD40 in the head then gentley tap a hardened bit into the bolt head.
    Carlos.
    • Fat Audi 80
      • 10547
      Wire brush if they are rusty.
      The Perfectionist
      • Jas11n
        • 5067
        And don't use an allen key, you will round them off inside.
        Use a good allen socket. Heat them up first if you can and use some penetrating fluid.
        I replaced all four (two each side) of mine with high tensile replacements with a hex head instead.
        2001 Avus Silver B5 RS4.
        1995 S2 Coupe - sold (sniff)
        • goodall
          • Jul 2008
          • 810
          cant remember the size, but for me was a case of, using the professional driver set, which you have to generally hit in with a hammer, and impact wrench, even that was getting it hard to loosen the blots
          hope that helps
          • Flat on my back
            • Jan 2007
            • 2449
            Forget allen keys...even good ones...must be a hardened bit.
            Carlos.
            • mikeraz1
              • Jun 2008
              • 342
              I think at least one of the bolts is rounded off. Any suggestions?
              • Flat on my back
                • Jan 2007
                • 2449
                Nut extractors...cant think of the name...off to google.
                Carlos.
                • goodall
                  • Jul 2008
                  • 810
                  as said could try drilling it and using a , easy out, think ones i have called that, but tend be brittle and snap, if have you a welder, weld a bolt onto the head the existing bolt. the heat from welding will hopefully help loosen it
                  • mikeraz1
                    • Jun 2008
                    • 342
                    thanks for the help guys, think I might have things sorted now.
                    cheers
                    mike
