Brake funnies (master cylinder?)
  • Rusty
    • 18953
    Right, started the car up earlier (after doing the K pin mod ) and the brake pedal was pulsing with the PAS pump. This has happened a few times before, usually after emptying the bomb on a test or when the brake pedal has been pressed during interior maintenance. On previous occasions this has gone away withing a minute, this time however, it stayed...
    I took the car out for a drive and the pedal was still pulsing, the brakes were pretty poor / shocking so I drove slowly, hoping that time alone would sort the problem as on previous occsaions. I was out for over 15 mins and when I got back... still the same. Arrrrrrrrrrrrrrrgh Ordinarily I'd have left the job till the morning but as it's MOT at 9.30 I kept going on it despite being knackered after the autocheck BS earlier...
    So I decided to have a look at the system, pretty thoroughly, no leaks, brake and PAS fluids were both where they've been for ever and there were no visible leaks on the pipes, rack etc.
    So by this point I was ed to the max and started to . After drying my eyes, I then inspected the master cylinder from inside the car and decided to press the brake pedal by hand... and guess what... the bloody problem fixed itself in 2 presses by hand
    MAGIC HANDS ??? (That's what I tell the ladies anyway )
    I think I must have disturbed the seals when I was poking the actuation rod on the master cylinder. Unfortunately magic hands aren't a particularly scientific solution so I had a think about the components in the system; bomb, pump and master cylinder. The pulsing indicates to me that the pump is fine, the bomb has done 5000 miles and passes the bomb test last time I checked, I'll have a go tomorrow post MOT.
    So that leaves the master cylinder... my thoughts are that the seals might be worn such that when I fiddled the rod the seals re-seated. I don't know how the master cylinder workes exactly but I guess that it has 2 circuits as per a vacuum assisted unit. One circuit that feeds the brakes and another that assists pressing the pedal, both separated with a seal of some description to ensure a pressure differential. I must assume that the assistance side is higher pressure than atmosphere and thus at rest could leak past the seals to the brake circuit, which is at atmosphere. This would explain the pulsing with light pedal pressure.
    So then, any help, experience or advice? I think a new master cylinder is going to materialise at some point as either the seals or the bushes need replacing...
    I had this when my servo went mate, except my hands weren't magic enough to fix it
    • Flat on my back
      • Jan 2007
      • 2449
      Switch off ABS and try again, should tell you if it's related to the 'rings' or sensor/s.
      Carlos.
      • Rusty
        • 18953
        I hope the bomb hasn't gone, it's done about 5k miles! Will check the ABS but I'm fairy sure it's not that as it's a different feeling but still, could be wrong... Had the bomb go a while ago, was a mare on track . I think this is different. Will need to get a price on a master cylinder. Hope it's not bespoke like the clutch master cylinder and thus double the cost of a stock 80 part...
        • LHD_Kid
          • May 2006
          • 3697
          Ditto, I had the same - and was the servo...
          Hope you get it sorted....!
          Chris
          • Rusty
            • 18953
            How is the pressure transferred from the bomb to the master cylinder. I've never bled that section of the brake circuit nor can I remember seeing an easy way to do so. Is it that section filled with brake or hydraulic fluid?
            • bertman
              • Apr 2007
              • 1173
              • Current: United Kingdom
              The pressure is transferred from the side of the bomb,which runs along the bulkhead to the servo.The other pipe going to the underneath of the servo enters into the steering rack.There is no brake fluid in the hydraulic system to do with the brakes,only hydraulic fluid.
              Got a new master cylinder from pete at QC,cost around ÂŁ150.00
              HTH
              Rob
              Ragussa green avant RS2+ spec
              Racing blue Octavia VRS mk2 estate-Remapped now to 250 bhp
              Audi coupe gt-slow as hell but loads of character-sold
              • bertman
                • Apr 2007
                • 1173
                Sorry got the pipes muddled,top of servo goes to the rack and other way round
                Rob
                • Rusty
                  • 18953
                  Right. Done a bit more searching, where is the servo located? Is it part of the master cylinder or separate? I've found a leak test for it so will have a look later on. Car is currently at the MOT place , fingers crossed...
                  Please can someone post a family album pic of the master cylinder as I am without my computer at the mo.
                  • Nuvo
                    • Nov 2003
                    • 3828
                    Here you go Andy.
                    ABY master cylinder:
                    • Rusty
                      • 18953
                      Thanks Nuvo, is the hydraulic servo on a different page?
                      I need to check the servo later and see if it's leaking when you disconnect the drain line.
                      The master cylinder would appear to be fine as the brakes work well, it's the assistance that's the issue so that's bomb, servo and pump.
                      • Nuvo
                        • Nov 2003
                        • 3828
                        Yes, it's on a separate page
                        Here is the servo and its related parts.
                        • Rusty
                          • 18953
                          Much obliged will see if I can find a decent secondhand servo and try it. Labour is free so don't mind doing the job twice...
                          • LHD_Kid
                            • May 2006
                            • 3697
                            It will be the servo which is the problem... Accessed from the engine bay and by undoing 3 nuts from iside the car which holds it to the bulkhead. Also, disconnecting from the brake pedal.... It's a bit of a pita, but not too difficult....!
                            Chris
                            • Nuvo
                              • Nov 2003
                              • 3828
                              No problem, just recheck that last diagram as I posted the wrong one initially. The correct page is in place now. Good luck.
