Yeah, that's where I'm at with it, the rest is cood as far as I'm concerned and the fluid is nice and new. Will see what pops up on my wanted thread.
Brake funnies (master cylinder?)
Just revisiting this. It seems to be worst after the car has sat with the engine off and the brake pedal on. Like when the MOT man is sat in it or it's on the 4 wheel alignment jig... The pedal is fine at all other times... back to the servo search methinks
1994 ABY Coupe - Projekt AlpinweissComment
I had the same on my CQ after changing brake lines / bleeding brakes the day before the MOT test. Problem went away after a few miles and never came back. Put it down to a combination of weak pump and bomb taking there time to pressurise. A worn servo would make sense though, never thought of that...91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald ExpressComment
Bomb is new, PAS pump seems fine. I thought maybe air in the system but that doesn't make much sense. If I could get a clear schematic of what goes where and at what pressure then I could make more headway on it. Could be a blockage somewhere I guess, due to dirt. As with yours tho, when it's all working, it stays working, it's only when the car is sat with the brake pedal on for a prolonged period that it goes wrong... usually at MOT and 4WA
Brake pedal on for a prolonged period is the cause no doubt, i would have done that many times bleeding the brakes. I've never dismantled a servo so i'm not sure whats in there, think it works by magic just like a power steering rack. Something to do with high pressure either side of a cylinder assisting its movement. In any case i would bet its just a worn seal / bore thats bleeding off pressure. Going to see if i have one and take it apart...91CQ20v - Gone to a new home
Good evening squire, did you manage to take 1 apart? I'm going to dismantle my original 1 tomorrow. Last qoute i got was £450 from Pete at Quattro Corner, bought a bomb off him some time ago so going to fit that first tomorrow & see if it makes a difference?Brake pedal on for a prolonged period is the cause no doubt, i would have done that many times bleeding the brakes. I've never dismantled a servo so i'm not sure whats in there, think it works by magic just like a power steering rack. Something to do with high pressure either side of a cylinder assisting its movement. In any case i would bet its just a worn seal / bore thats bleeding off pressure. Going to see if i have one and take it apart...
ATB
RAOULComment
Link dont work.
I found the new servo i have but didnt have the nerve to dismantle it, brake pedal pushes on one end of it, which in turn pushes the master cylinder on the other end. I have a second hand one somewhere, i'll dismantle and take photos as soon as i can find it..91CQ20v - Gone to a new home
) as only the 3b's got the abs switch.
