think ross was the last one to go there for his just before his ruby red rs2 rep went for the mot so worth dropping him a pm and checking if thats where he used.
rs2 hardline/ goodridge hose part number required
I already had the hardline replacement flexi on... will need this one on the RS2 at some point though as that has hard lines on the front. I'm sticking with this car now, getting fed up spending $$$ doing the same work again on another car
Part I needed was the chassis-strut flexi's for the front, can't believe what a difference that made to brake feel, if those are still rubber then do both - the 'kit' is not much more than getting a one-off made for just the caliper lines
so is it not just possible to make one longer line from the chassis hardline out to the caliper? I just have the RS" hardline goind around the backof the caliper using the old support arm and rubber bush then connecting to (at the time) new strut to chassis line rubber flexis.sigpic
1992 3b S2 CoupeComment
David - that was presented to me as an option, rather than using the small hardline section, but aparrently you'll have to make sure it is secured to the strut for MOT (perhaps one of our resident testers can confirm?)
I didn't actually buy a specific part from merlin, just gave them the spec and mentioned the kit it was from, they make them up to order so just give them your requirement. Was with me the next morning
