RS2 Big red pads???
Under my RS2 I have the EBC Yellowstuff brake pads on front with big red and on rear with the original 299 mm brake disk but drilled, I use this pads on normal road and also for trackday and I'm very happy with this brake pads, the only problem is the dust I think. Bye
AlessioMy life and my loves
Audi-Porsche Avant RS2
Audi S6 C4 ABT Avant
Audi S2 Coupe ABY
Audi S2 Avant
Audi Cabriolet 2.0EComment
Yellowstuff were bush when I used them at ADI on track.1994 Audi S2 Avant - in pieces
2006 Skoda Octavia vRS 2.0TFSi - goes fast
1985 Audi 90 quattro - is wet
Don't forget the East Midlands Meet -Last Tuesday of every month at 7:30pm just off M1 J28!![/COLOR]Comment
http://www.circuitsupplies.com/ get mine from here Tom if you are referring to RS2 OEM big reds. They do DS2500 which are slightly thicker than standard. Never had an issue on the standard disc if part worn. On new discs you may get contact however circuit supplies will order the pads 'shaved' IIRC 1mm but check. Last year cost ~ £160. Part no FCP891H there is a thread here or RS246Alastair
RS2Comment
