RS2 Brake pads and discs part numbers
This is a sticky topic.
  • A80Avant
    • 10873
    • Country: Greece
    Does anyone have the porsche part numbers for this? I have ordered before and I have lost my useful paper which had them in...
    I need the part numbers for the rears really as there are various options for the 299/24
    • Mr G
      • Jun 2008
      • 196
      • Country: South Africa
      I assume you're looking for the rear pad part number - if so this is what I have on hand 965-352-939-04
      • A80Avant
        • 10873
        • Country: Greece
        • A80Avant
          • 10873
          • Country: Greece
          I'm actually looking for the rear disc part number
          It looks like the part numbers I have show me a disc that has a fairly deep hat in contrast to what the car has currently on and I have always used. So since this time I plan to order stuff from a porsche dealer I'd like to order them correctly.
          I believe the rear disc also comes off the 965 as well as the front, cross drilled and the photos match the genuine discs, but on the online shop they have a photo of the aftermarket disc which doesn't match the had deepness of the genuine disc so I'm asking them a question in regards to that. It also appears that the 944 shares the same rear disc but not cross drilled.
          • Mr G
            • Jun 2008
            • 196
            #20
            The below was my findings a while ago
            "For what it's worth - had the rear disc of my RS2 yesterday - and the part number on the disc is 951-352-041-60. Took it to a Porsche dealer, and the hat on the 951-352-041-01 is about 20mm higher"
            These are the standard discs not cross drilled etc.
            I still haven't replaced the rear discs
            • A80Avant
              • 10873
              • Country: Greece
              #21
              Yes. I believe that the rs2 uses shallower hat. that's what's my rear discs as well.
              • A80Avant
                • 10873
                • Country: Greece
                #22
                https://www.design911.co.uk/mobile/#part;id=5558
                These are the only ones that look like the rs2 ones but I don't have that part number in my logbook as being ok for the rs2. I need to ask them the dimensions
                • A80Avant
                  • 10873
                  • Country: Greece
                  #23
                  I cannot find that part number I'm afraid
                  • jade
                    • Jan 2005
                    • 1811
                    • Home: New Zealand Current: Spain
                    #24
                    I far as I am a ware 928 rears fit also, but not drilled
                    RS 2 580HP
                    • saltinot
                      • May 2004
                      • 1946
                      #25
                      Correct, there is no OE Porsche equivalent for the cross-drilled rear discs on the RS2. You can source them from Zimmermann, listed in under the 928 line, but they do have the same appearance as OE.
                      The non-drilled rear discs from the later 928, i.e. GTS, can be found at your Porsche dealer.
                      • saltinot
                        • May 2004
                        • 1946
                        #26
                        • A80Avant
                          • 10873
                          • Country: Greece
                          #27
                          If the 965 ones which the front 322/32 come from are 299/24 then that should be the equivalent one
                          • A80Avant
                            • 10873
                            • Country: Greece
                            #28
                            I want the cross drilled ones as I have drilled in front
                            • saltinot
                              • May 2004
                              • 1946
                              #29
                              Then you'll need to source them from Audi or from Zimmermann. Your picture, posted at 10:06am, is a picture of the Zimmermann disc, BTW.
                              I have researched this for a long time and was unable to find an OE Porsche equivalent. There might be one out there so if you can find an OE Porsche cross-drilled rear rotor to fit the RS2 please post the number.
                              I bought the non-drilled ones for the time being......I'll soon be forking out the dough to buy the OE ones from Audi.
                              • A80Avant
                                • 10873
                                • Country: Greece
                                #30
                                On the type911 shop the rear discs aimed for the 965 porsche are identical to the oem audi ones. Those are genuine porsche with the short hat and drilled. So I am in the process of finding out if they are 299/24 and if they are although they are almost 200£ a piece, at least those could do
