hi,
let´s have a look on the pictures:
Special MTM/Hohenester/SMS Wheel bearing carriers for HP2 brake on the S2, in comparism to the orig. S2/RS2:
perfectly fitting RS4 B7 carrier:
amazing difference between the sizes of the caliper and the wheel bearing carriers:
all mounted:
and on the car:
list of parts needed:
-special HP2 wheel bearing carriers (which are sadly anywhere no longer available, because i´ve bought the last set of those)
-phaeton hats
-original rs4 b7 calipercarrier little bit modified
-rs4 brake discs
-rs2 metall brake line ( fits perfectly )
-rs4 b7 calipers
-s2/rs2 wheel bearing
-rs6 wheel hub little bit modified
and everything fits perfectly. the calipers is perfectly working on the brake discs.
hope you enjoyed it
wolfgang
all mounted:
and on the car:
-phaeton hats
-rs4 brake discs
-rs4 b7 calipers
hope you enjoyed it
wolfgang
