Please help me, i have ordered a set of rear drilled OEM Audi RS2 discs, and I reqiuire a set of shiny new fast road pads. Whats the best that not too ****** on normal drives, and where is the best to buy?
Best RS2 Fast Road Pads Front & Rear? Help.....
Tags: None
Ferodo DS2500 is the answer, without doubt.
I went from EBC Redstuffs that were scary bad to the Ferodos that are scary powerful. Night and day is an understatement.
www.raceshopper.com is probably cheapest, but perhaps not after import tax, etc.1995 RS2 on Alcohol (6.8sec 100-200km/h)
1994 80E Avant
1986 2L Golf 2 on Alcohol -
textars is crap! mine was fading after 5laps and i brake on the right way..
i am going to run carbotech xp10 in front and carbotech xp8 @ rear,
but most importatnt, fix better cooling than oem plastic thingy on the controlarm, i am going to connect a hose to my air inlet in the frontbumper.
One thing i've learned we are way behind the Scandinavians!Comment
The DS2500s are the tried and tested all rounders although GT500 Rob does strongly favour some others that i cant recall atm (pm him and ask if he doesnt reply here)S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
1994 80E Avant
1986 2L Golf 2 on AlcoholComment
i noticed taht is was for tarck use after, sorry... then ferodo´s 2500 will be great:humbs:
Stiglet, here in sweden everybody runs carbotech? ( and if not : ferodo´s / Pagid or some pads that have come up recently is Hawk, dont know any about these though..)
many beemers in sweden running carbotechs with good results( and again, brake cooling!), they scream a little when they´re cold, but has normal braking power, when they´re warm, brake and it feels like hit a wall
Yup, Pagid RS29. I'm on my second set. Expensive but very long life for both discs and pads and massive performance. They can occasionally make a squeek if you;ve not thrashed em for a while but a quick blast sorts them out.RS2+ (now sold...)Comment
from what ive seen ebc are the best for no dust but many have issues.
reds are pretty poor in when cold it must be said. when hot they stop. i run them on the 6 pots. at the time they were over £100 cheaper than ds2500's.
id go ds2500 next i think. if they are less than 200 a set.Comment
